8/28/2015 6:34 PM | |
Joined: 5/12/2006 Last visit: 2/18/2025 Posts: 22544 Rating:
Hello, the card is compatible, a document doesn't exists.
Christoph |
8/29/2015 1:04 PM | |
Posts: 1058 Rating:
I did not find such document, but generally you can use Siemens SD-cards with Siemens panels always. there should normally be no problem. However, there have been some problems in past with not correctly formated SD cards: Why is the SIMATIC HMI SD Memory Card not recognized in a Comfort panel?regards |
