11/12/2007 2:27 PM | |
Joined: 10/31/2006 Last visit: 9/21/2022 Posts: 134 Rating:
Hi Rico, here is an exampe that I use and it works fine. Make sure you have IIS and SMTP installed on the machine you are going to send it from.
Dim S |
Last edited by: CromptonS at: 12.11.2007 14:50Last edited by: CromptonS at: 12.11.2007 14:43 |
3/17/2009 1:47 PM | |
Joined: 11/15/2007 Last visit: 9/5/2023 Posts: 11 Rating:
Hi, I'm trying (without any success) to run this script and send e-mails over a server which requires authentication. Anybody succeeded on this? I found these additional settings, but could not implement them: objEmail.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/smtpauthenticate") =1 objEmail.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/sendusername") = strUser objEmail.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/sendpassword") = strPass |
