11/15/2016 7:11 PM | |
Posts: 439 Rating:
Hello Borutti, As far as I know, SD card is the only place you will be able to put file in a S7-1200. There is an application exemple that could guide you in the right way. Using recipes with S7-1200On the first view, I think they import csv file into the SD card and then it is use to change the recipe. Maybe somebody else have a better idea. Best regards, Hugo |
