9/8/2008 9:19 AM | |
Joined: 9/7/2007 Last visit: 10/9/2024 Posts: 550 Rating:
Dear Shiv Please check this link: http://support.automation.siemens.com/WW/view/en/27038105 and you can also do it with S7-200 Micro automation Set5: https://www.automation.siemens.com/microset/html_76/solutions/mas05.htm |
Best Regards |
9/8/2008 9:52 AM | |
Joined: 4/24/2006 Last visit: 3/18/2025 Posts: 8897 Rating:
Hi, Here is just another link: Sending and Receiving SMS messaging with s7-300/400 via serial CP's (340/341/441-2) and the GPRS/GSM Modem MD720-3 Best regards, Wizard |
9/9/2008 12:13 AM | |
Posts: 264 Rating:
Hello Shiv, Some more infos for you: If you want just send sms from your plc, you should use a TS-Adapter, because it includes comperatively easy functions for sending sms. further pros like Karl told us: remote maintenance possible, data link to other S7-300 plc + TS-Adapter is possible (also GSM <--> Analog) con: You may also needTS-Adapter-Software http://support.automation.siemens.com/WW/view/en/19880024 When you also want to teleswitch (sending a sms from mobile phone to plc and operate something (quit, start pump, ...) you should use CP340 + MD720-3 like descriped here: http://support.automation.siemens.com/WW/view/en/25545680 further pros: You can adapt the program (SCL!) for extended functions (e.g: call before sending sms to a phone, ...) you can also use a independend plc e.g. S7-200 + MD720-3 like Khaled_Ezzat and AMAZINGAHMED told us https://www.automation.siemens.com/microset/html_76/solutions/mas05.htm http://support.automation.siemens.com/WW/view/en/27038105 Also possible: PC + SCADA + AlarmControlCenter, a productfrom Siemens I&S.. https://www.automation.siemens.com/hmi/html_00/products/software/wincc_addons/wcc_addon_alarm_management.htm best regards.. |
Last edited by: neo at: 9/9/2008 12:21 AMLast edited by: neo at: 9/9/2008 12:21 AM |
