4/26/2015 10:10 AM | |
Posts: 2 Rating: (0) |
Dear Sir is there a sensor that will sense the humidity and the application is Soil ---------------------------------------------------------------------------------------------------- |
Last edited by: Min_Moderator at: 4/27/2015 4:30:30 PMNew subject after splitting |
4/29/2015 9:29 AM | |
Dear thank you very much it will really help . I thought that Siemens Has a Soil sensor. any how my project now will have a Non-Siemens element |
7/7/2018 12:22 AM | |
Posts: 3 Rating: (0) |
Hello Yazan Did the novalynx sensor worked for you? Did you conected the probe to 24Vdc or 10Vdc to achieve correct measurements? |
7/12/2018 3:55 PM | |
Posts: 10 Rating: (0) |
https://www.aliexpress.com/item/4-20MA-Current-Output-Waterproof-Soil-Moisture-Sensor-0-2V-Voltage-Soil-Temperature-Moisture-Sensor-for/32849255839.html
