11/2/2021 11:32 PM | |
Posts: 257 Rating: (75)
Hello SIOS Forum Community The following article shows how to connect a sensor with 3-wire connection (3-wire transmitter) is connected to the analog signal modules of the SIMATIC is connected. How do you connect a sensor to the analog signal modules of the S7-1200/S7-1500 and the ET 200MP? Note The procedure described in this article refers to the time of writing this article (status: November 2021). With kind regards SIMATIC International Technical Support Hub |
