3/21/2015 9:07 PM | |
Posts: 31 Rating:
Hi .. (best way to start I am trying to capture a serial string using CM12the 41 I can get the data in to the PLC (1214C) BUT!!! How can i "sniff" for a start text and then cature only that line in to a string (array off char to sting conversion) ? Data string could be: $GPRTE,1,1,w,0,*3F38505.93,N,01441.3 $GPVTG,062,T,059,M,00.0,N,00.1,K,D*2F0000,E,,W84*71N,,K*4AALR $RAVTG,295.0 Say i want the line starting with $GPVTG. And why can i get 2 char's i an array (see attached) in the monitor window,when i monitor the buffer? Sorry for the bad english. Attachment2 char i char var.pdf (99 Downloads) |
