1/2/2012 10:35 AM | |
Joined: 9/8/2009 Last visit: 7/17/2023 Posts: 1410 Rating:
I think is a problem in parameters. |
1/3/2012 10:16 AM | |
Posts: 140 Rating:
Hi Marko, Can you elaborate a bit more on the possible issue? Thanks!
1/4/2012 12:59 AM | |
Posts: 140 Rating:
Hello Marcjan, I am using 315-2DP, Just for your info, I am using 2 sensors which are serially sending data to PLC. I swapped the position of two sensors on the PLC and that worked fine, serial communication didn't stop for 5-6 hours untill I switched off PLC to finish my testing. I have attached the code being used for serial communication! Thanks!
AttachmentLegIm_31.zip (162 Downloads) |
1/9/2012 12:40 AM | |
Posts: 140 Rating:
Hello Experts, Any suggestions for the issue? Thanks!
1/18/2012 4:17 AM | |
Posts: 140 Rating:
Hello Experts, Please advice on the issue asap, I will be grateful to you! Thanks in advance! |
1/18/2012 10:46 AM | |
Posts: 1547 Rating:
Hi, it seems that anybody has an overall idea on this issue. I suggest to contact the technical support. |
1/25/2012 8:16 AM | |
Posts: 140 Rating:
Thanks a lot for replying back! Can anyone tell me how can I change the baudrate for CP-341 RS422 communication? I can't find any option to do so! Thanks!
