5/7/2019 3:30 PM | |
Joined: 7/7/2010 Last visit: 3/10/2025 Posts: 15721 Rating:
To locate Siemens solutions quickly, you can use the Industry Mall (Siemens). https://support.industry.siemens.com/cs/products/6es7241-1ch30-1xb0 Select Entry Type of Application Example. It currently shows 4 working examples using that module. You can download them and try them out to see if they are at all helpful. The manual is also available from the same link (above). I recommend getting the manual as well so you can take full advantage of the module for your application.
science guy |
5/8/2019 12:58 PM | |
Posts: 3093 Rating:
Hello, Regards, |
