7/25/2006 8:18 AM | |
Posts: 3149 Rating:
Hi, this issue has already been discussed several times in the english forum. Just search for "wincc master"... nemo |
7/25/2006 9:40 AM | |
Posts: 1084 Rating:
Hi, And read the WinCC Information Help (installed on your system after installation of WinCC). with regards, Ikkezelf |
7/26/2006 4:15 AM | |
Joined: 5/25/2006 Last visit: 9/6/2023 Posts: 28 Rating:
I always look at the forum before posting a message, but only found some messages about the internal tags from the redundancy... those flags (@RM_MASTER, @RM_MASTER_NAME, @RM_SERVER_NAME) don't help me to much. I was looking for something like lifebit monitor. With a little modifications, I now have the light for the servers, so the clients can know when a server is down. I will put here a link that help me a lot: https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&lang=en&objid=9918678&caller=view The Lifebit.pdf that came with the WinCC documentation has goodinformation too... sorry, I didn'tnotice that pdf before [:blush:]. Anyway I would like to say thanks guys for your time and help. Best regards |
7/26/2006 7:50 AM | |
Posts: 3149 Rating:
Hi, if you check the content of the @RM_master-tags you can see, which of your servers is the "master", that´s what you intended to display. nemo |
10/28/2009 2:14 PM | |
Joined: 3/21/2007 Last visit: 7/25/2023 Posts: 29 Rating:
Or you can evaluate tag status in Dynamic Dialog... LP |
