3/25/2009 10:10 AM | |
Posts: 23 Rating:
Thx. I will avoid using negative number. |
3/25/2009 5:09 PM | |
Joined: 4/5/2006 Last visit: 9/15/2023 Posts: 917 Rating:
Hi P.C., Tolleifis right, better use Hex mask, more easier to understood and maintenance.
One more, that code works on "Unsigned 32 bits" WinCC tags, when you ry to use that code using decimal negative number mask on "Signed 32 bits" WinCC tags...nothing happens. So, have a look what tags format are you using. Regards |
3/31/2009 4:47 AM | |
Posts: 23 Rating:
Thanks! Very helpfuland detailed explanation. |
