4/11/2016 5:38 AM | |
Joined: 5/28/2008 Last visit: 3/17/2025 Posts: 4518 Rating:
Hello, For S7-300/400 & WinCC flexible: How do you synchronize the date and time between an operator panel and an S7-300/S7-400 controller with WinCC flexible?For TIA Portal: Clock synchronization between a HMI operator panel and a SIMATIC PLC |
Ayman Elotaify |
4/11/2016 5:45 AM | |
Joined: 3/28/2015 Last visit: 2/15/2025 Posts: 722 Rating:
Hello, Kindly have a look at this topic: Time synchronization - Time synchronization in the automation environment |
Eng.Mohamed Ibrahim |
4/21/2016 1:50 AM | |
Joined: 9/27/2006 Last visit: 3/18/2025 Posts: 12344 Rating:
Hello anayisse; Have a look at the following Application Example discussing various scenarios of time synchronization between PLCs (including a S7-300) and TP1200 (as an example), using TIA Portal. Clock synchronization between a HMI operator panel and a SIMATIC PLC https://support.industry.siemens.com/cs/ww/en/view/69864408 Choose the function that best suits your needs and use the included function blocks to set up your own program. Hope this helps, Daniel Chartier |
4/22/2016 1:31 AM | |
Posts: 40 Rating:
i saw the document but this example is using ETHERNET OR my plc don't include ethernet what can i do ,?? |
4/22/2016 12:17 PM | |
Posts: 40 Rating:
how to open this kind of projects ?? always same problem when opening |
