6/27/2010 10:11 AM | |
Joined: 2/6/2009 Last visit: 4/19/2023 Posts: 932 Rating:
Dear All, Here I have attached a program backup contains the block for The block can be used for both Set as well as reset. This block is not having anydependencywith MCR. This can be used for Memory Bits, Digital Outputs and DB bits. Revert back for any clarification. AttachmentSet&Reset_Bits.zip (149 Downloads) |
Last edited by: Saravana kumar at: 6/27/2010 10:14 AM_______________________________________________________________ |
3 thankful Users |
6/29/2010 5:54 PM | |
DearY.DHINAKARAN, I am not able to get your question clearly. Can you ask in brief. The use of the block is to Set / Reset Range of Bits in Memory Bits, Digital Outputs or DB bits.
