9/28/2014 7:20 PM | |
Joined: 5/24/2009 Last visit: 12/13/2022 Posts: 90 Rating:
I have consistent problems getting the time set in a KTP1000 basic panel. In the "connections" panel I have set the date/time PLC in the 'Global Area Pointer of HMI Panel' to a datablock containing a DTL field called "now" and selected the proper connection. Although the datablock contains the correct time, the HMI time remains unchanged... What can be the problem... Hans
AttachmentCapture.pdf (236 Downloads) |
9/29/2014 8:46 AM | |
Joined: 4/24/2006 Last visit: 2/2/2023 Posts: 8586 Rating:
Hello HansAST, Perhaps the following link might help: how do you synchronize the time of the HMI Basic Panel with an S7-1200 PLC? Best regards, Wizard |
9/29/2014 12:04 PM | |
Thanks, but I already looked in that document and I think my setting is the same. Yet it does not work.... |
