6/7/2022 9:35 AM | |
Joined: 4/28/2015 Last visit: 12/1/2023 Posts: 3294 Rating:
Hi, when you want to connect a monitor to display node-red, you need to install a desktop environment. How to do this is described here. You will then need to install a browser, e.g. Chromium and add a autostart script to automatically start it. Some more info can be found here. Accessing this from "outside" via VNC you need to install a VNC Server on the IOT2050. There is different instructions in the web, e.g. this one. Best regards! |
