1/22/2020 1:47 PM | |
Joined: 9/9/2014 Last visit: 1/25/2023 Posts: 237 Rating:
Hello, So what's the problem? Use the modules you have proposed for your tasks - no problem. If in doubt, use the compatibility check utility: TIA Selection Tool – quick, easy, smart configuration This is the best way to test your decision. Or add the modules inside the TIA PORTAL - and check everything there ... |
Best Regards |
