5/12/2018 1:32 PM | |
Joined: 5/6/2010 Last visit: 6/4/2023 Posts: 1885 Rating:
Hello Bigdiagne, you can look at this manual , there is a description of the LED's. There are some errors which are only quit with switch OFF/ON of the IM. Hope this is helpful. regards |
Last edited by: CaOd at: 5/12/2018 1:35:30 PMLast edited by: Jen_Moderator at: 5/14/2018 9:39:24 AMOptimized link. |
5/13/2018 1:42 AM | |
Joined: 9/27/2006 Last visit: 6/5/2023 Posts: 12034 Rating:
Hello Bigdiagne; If by "socket" you refer to the Profibus connector between the Profibus cable and the slave (or master) node, I think the contents of this discussion should interest you: https://support.industry.siemens.com/tf/us/en/posts/profibus-connector/166519/?page=0&pageSize=10 It points to an article that shows how to test connectors using a standard multimeter. Hope this helps, Daniel Chartier |
