11/24/2009 12:37 AM | |
Joined: 10/7/2005 Last visit: 6/5/2023 Posts: 2966 Rating:
Hello Berg if you are conected to your 315 simply press the "online view" shortcut icon (or select "online" from the "View" drop down lenu) and have a look if SFB32 existsin the CPU (I have a feeling it will be listed,it does certainly exists in the instruction list manual for the latest 300's). If it exists in your 315 it will have to work as per manual/<F1> help (Inever had the need to use it and can't unfortunately give you any hints on its usage). Note that SFB32 is alsolisted as a supported SFB for PLCSIM V5.4 SP3. I hope this helps |
Cheers |
