5/22/2018 2:51 PM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello Majklix I´m not sure if that is your Problem but I think there is no "FolderExists" method in the Filesystemobject in WinCE on comfort Panel! You have to work with DIR method. (Sorry I have not analysed the whole Script...) And be sure that your Network share is connected correct: https://support.industry.siemens.com/cs/ww/en/view/92346478 Bye Murof |
