3/7/2009 10:32 AM | |
Posts: 48 Rating:
Hi there! You can try method as described in help under "Output parameters for hardcopy" Good luck!! |
3/8/2009 2:23 PM | |
Posts: 14 Rating:
3/10/2009 10:39 AM | |
Hi Howi See, you can not use the spacebar as hotkey, but the most other keys can be used as Hotkeys with the object "button". properties > "Miscellaneous" > "Hotkey". Hardcopy is a tool to make screenshots, i think you would not do that, rigth? regards cumulus |
Learn more about visualization - visit the HMI courses of Siemens AG! |
3/10/2009 11:21 AM | |
Joined: 1/17/2006 Last visit: 10/27/2023 Posts: 799 Rating:
You can try to "catch" the key "spacebar" with anaction |
