11/24/2008 3:03 PM | |
Posts: 38 Rating:
Hi, I am having a problem when I try and import the tags into WinCC via the SICAM wizard. I am using WinCC V6.2. When I try to import the tags into WinCC, the wizard starts up but then an error appears saying that the wizard has encountered an error and needs to close. Has anyone experienced this before? Thanks Attachmenterror.zip (71 Downloads) |
11/24/2008 3:36 PM | |
Posts: 38 Rating:
Hi, I was able to fix it by installing the WinCC hotfix. |
