2/11/2010 11:07 PM | |
Posts: 19 Rating: (0) |
Thanke you for this quick answer and help. |
2/15/2010 1:56 PM | |
Today i got Winpcin version 1.2.0. Will this version of software be ok to connect with 820M? |
2/15/2010 5:26 PM | |
Posts: 11 Rating: (1) |
Hi, you can reload and fix your NC by fowlloing the steps which is described in attached file.meanwhile I'm not sure you can use the winpcin for reloading your data to NC ?!! but I know that you wouldn't have any problem with "PCIN". you must use a PC or Laptop with serial port,because the USB2Serial converters driver doesn't work in MSDOS. WR. Attachment810_820 reload.pdf (310 Downloads) |
2/16/2010 11:50 AM | |
Thanke you for the answer. I will have to try with Winpcin because i cant get the dos version i have only for windows |
2/22/2010 8:07 AM | |
In attachment is my pictures of my problem. Anybody know how can i solve my problem with NC alarm? |
