9/18/2015 1:53 PM | |
Joined: 1/28/2009 Last visit: 6/1/2023 Posts: 6803 Rating:
Hello,
First , you need check the following manual (documents) for a step-by-step description.For S7 side, you only need to find the GSD file for related CPU and add in your master side (AB/Prosoft).To access all SIMATIC gsd file, check it HERE. I need to set up a ProSoft PROFIBUS Master to talk to a Siemens S7-300 series CPU that is set up as a PROFIBUS Slave. How do I do that?I hope this helps, hdhosseini |
3 thankful Users |
9/21/2015 10:03 AM | |
Posts: 25 Rating:
Thanks you this was helpful. The IO configuration on the PCB was incorrect in mine. |
9/21/2015 12:31 PM | |
Posts: 25 Rating:
Thanks i was able to establish communication, the documentation really helped. Appreciate you time |
2 thankful Users |
9/23/2015 10:43 AM | |
Posts: 160 Rating:
Hi, is there anything similar for TIA? Janko |
