1/11/2014 4:07 PM | |
Joined: 4/22/2010 Last visit: 1/15/2025 Posts: 5697 Rating:
Hello, That option is backtransfer, to copy the file, i think you can just copy the PDZ file. But you allways need Wincc-flex to get it back to the panel. How do you back transfer the projects of an operator panel and what should you watch out for? If you want to transfer a project without using Wincc-flex maybe this works for you. How can you transfer a WinCC flexible configuration without configuration software to an operator panel (Pack&Go)? Regards, Marcjan |
Problem solved? |
1/14/2014 8:20 AM | |
Joined: 4/24/2006 Last visit: 2/14/2025 Posts: 8848 Rating:
Hello No, you need a Panel (same type)to make a Backup to a CF/MMC card Here are some links: how do you backup/restore with a Comfort panel? how do you backup/restore with a Windows-based panel? Best regards, Wizard |
6/20/2017 6:07 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4766 Rating:
New question published by Edgmarb is split to a separate thread with the subject Does the backup from WinCC include the contents of the MMC. Best regards |
