12/20/2017 9:43 AM | |
Joined: 8/3/2009 Last visit: 3/20/2025 Posts: 15045 Rating:
Hello Ams there is also a White Paper for using IP V6 in Siemens Automation: https://www.siemens.com/press/pool/de/materials/industry/iia/whitepapers/whitepaper-ipv6-e.pdf It should be interesting for you and your IT. Bye Murof |
3/29/2020 10:47 PM | |
Joined: 3/12/2015 Last visit: 3/10/2025 Posts: 3 Rating:
Hi, I found this document: |
