7/9/2019 1:21 PM | |
Joined: 12/18/2014 Last visit: 9/19/2024 Posts: 33794 Rating: (4199) |
The following new advisories/bulletins have just been published on the Siemens ProductCERT web site [1]: - SSA-121293: Code Upload Vulnerability in SIMATIC WinCC and SIMATIC PCS7 [2] Additionally, the following advisories / bulletins have just been updated on the Siemens ProductCERT web site [1]: - SSA-166360: Vulnerability in Advanced Therapy Products from Siemens Healthineers [8] [1] <https://www.siemens.com/cert/advisories/> [2] <https://cert-portal.siemens.com/productcert/pdf/ssa-121293.pdf> [3] <https://cert-portal.siemens.com/productcert/pdf/ssa-556833.pdf> [4] <https://cert-portal.siemens.com/productcert/pdf/ssa-616472.pdf> [5] <https://cert-portal.siemens.com/productcert/pdf/ssa-721298.pdf> [6] <https://cert-portal.siemens.com/productcert/pdf/ssa-747162.pdf> [7] <https://cert-portal.siemens.com/productcert/pdf/ssa-899560.pdf> [8] <https://cert-portal.siemens.com/productcert/pdf/ssa-166360.pdf> [9] <https://cert-portal.siemens.com/productcert/pdf/ssa-307392.pdf> [10] <https://cert-portal.siemens.com/productcert/pdf/ssa-480230.pdf> [11] <https://cert-portal.siemens.com/productcert/pdf/ssa-559174.pdf> [12] <https://cert-portal.siemens.com/productcert/pdf/ssa-616199.pdf> [13] <https://cert-portal.siemens.com/productcert/pdf/ssa-697412.pdf> [14] <https://cert-portal.siemens.com/productcert/pdf/ssa-832947.pdf> [15] <https://cert-portal.siemens.com/productcert/pdf/ssb-439005.pdf> |
