4/21/2018 5:04 PM | |
Joined: 5/6/2010 Last visit: 2/4/2023 Posts: 1859 Rating:
Hello Jacplacu, the answer to your question is not so easy. Here my suggestion - temperature control with pwm:
Then you can do the follow Wire two digital outputs to the load relay (then you can test heating and also cooling) Then you can test the PID with a minimum risk and with slow reactions. I hope this is helpful regards |
