11/12/2013 12:55 PM | |
Posts: 1 Rating:
Hi, I am fairly new to Siemens S7 but have experience with Mitsubishi and Allen Bradley systems. At present i am taking a few weeks to look into the Simatic Manager S7 software (I also have been given TIA Portal V12 to look at). I am creating simple logic just to make sure i can use all of the symbols, naming and simulation software parts. I am looking for the 'Special Bits' IE;- the name i can give to a N/O contact to allow it to read for the first scan only or a PLC healthy bit, does it have a specific internal memory bit that i can assign to a contact to use? I am trawling through manuals at the moment but thought this was worth a shot too. I did search the FAQ's for the post but didnt see much, if i have repeated then i apologise. Thank you in advance Regards Dan |
11/12/2013 1:44 PM | |
Joined: 8/31/2005 Last visit: 3/24/2025 Posts: 2198 Rating:
The SIMATIC does not use special bits. Instead of this, OBs are called. |
11/12/2013 2:14 PM | |
Joined: 1/28/2009 Last visit: 3/29/2025 Posts: 6867 Rating:
Hello, For S7 300/400 ,We can consider the bit inside the status word as special bits.They are activated on special occasions as explained in the manuals.If you have experience with smaller CPUs such as S7 200,There are special memories to indicate the first scan or memory for cyclic behaviors.These options are not available explicitly but can be created if necessary.Please, check the following discussion as a sample: Hamid Hosseini
power up bitI hope that helps |
To explore the new Forum, you can follow the textbox in the right column, which will lead you to the corresponding page in the new Forum. Alternatively, you can start from the main page by following this link:
https://sieportal.siemens.com/en-ww/support/forum
In the coming days, we will update the configuration step by step, so that you are directed to the new Forum by default. The “classic Forum” will remain available for all known functionalities alongside the new one.
We are thrilled to finally share the future of our Forum with you. Thank you for your commitment!
Kind regards,
the Forum Support Team
