1/4/2013 3:38 PM | |
Joined: 4/22/2010 Last visit: 12/15/2022 Posts: 5697 Rating:
Hello, The question back is what analog card do you have? (partnumber) What is the partnumber of the transmitter? There are more than 1 i think. From this manual i understand it's a 2 wire sensor, if you have a analog card that can power 2 wire sensors you need 2 wire And ground. Regards, Marcjan |
Problem solved? |
1/4/2013 6:56 PM | |
Joined: 9/27/2006 Last visit: 9/27/2023 Posts: 12153 Rating:
Hello henrik; Please provide the complete part number of the analog input module you are using, or lookup the information on it in the following maunal: SIMATIC S7-300 S7-300 Automation System Module Data Hope this helps, Daniel Chartier |
