1/12/2022 9:47 AM | |
Posts: 40 Rating: (0) |
So if the factory requires SIL3, then the project must be made with a fail-safe controller, right? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 01/12/2022 11:40:21New subject after splitting |
1/12/2022 12:03 PM | |
Joined: 9/27/2006 Last visit: 9/23/2024 Posts: 12282 Rating: (2685) |
Hellp radu.ch; Yes, the Failsafe portion of your project (*) requires a F-CPU, F-I/O modules, and a Safety program. If using distribted I/O with F-I/O modules over Profibus or Profinet you will use the ProfiSafe profile. (*) An F-CPU can control F-I/O and a Safety program in parallel with a standard program with standard I/O. Here is a brief description of Safety finctions with Simatic Safety v17, the latest Safety programming software for S7-1500 F-CPUs. https://support.industry.siemens.com/cs/ww/en/view/54110126/142880040587 Hope this helps, |
