2/28/2011 6:12 PM | |
Joined: 4/6/2006 Last visit: 2/5/2024 Posts: 604 Rating:
Hi, Some important information is missing like Operating System, Step 7 version but I would suggest to follow the FAQ below, maybe one of the steps helps you finding a solution: What remedies are there when you can't load the configuration of the PC station? If this didn't solved your problem I would suggest to follow the following FAQ: How should you proceed if installation of the SIMATIC NET PC software is not completed successfully? |
Best regards, |
