1/20/2018 8:32 PM | |
Joined: 1/21/2013 Last visit: 5/6/2022 Posts: 4616 Rating:
Hello David, yes and yes, so you can also with Profibus but depend of your CPU if have Profibus port http://support.automation.siemens.com/WW/view/en/42918861 but pay attention this panel is Spare parts Data sheet 6AV6642-0AA11-0AX0 - Industry Support Siemens the new is with WinCC Tia Portal Basic/Comfort Panel with this https://support.industry.siemens.com/cs/au/en/view/73502293 However the MPI network is not supported can you give us the code of your CPU? 6ES7 31x xxxxx xxxx |
Last edited by: Ste39 at: 1/20/2018 8:35:44 PMLast edited by: Ste39 at: 1/20/2018 9:07:46 PMadded TP177A Spare parts Last edited by: Jen_Moderator at: 1/22/2018 11:29:48 AMInserted right link. |
1/20/2018 9:47 PM | |
Hello, PROFIBUS bus cables - Industry Mall - Siemens WW RS 485 bus connector - Industry Mall - Siemens WW have a look TIA V13, transfer project to TP177A - Industry Support Siemens seems so..... I never used TP177A with TIA Portal anyway I would go on a minimum a basic panel |
