8/17/2020 9:04 AM | |
Joined: 5/12/2006 Last visit: 4/22/2025 Posts: 22600 Rating:
https://marker.io/blog/write-bug-report/ |
8/19/2020 9:53 AM | |
Posts: 137 Rating:
Thanks for your reply here you can see in video. just made test with Switch and Button and both not working or changed the Variable in DB or the animation. thanks for feedback. Sorry, i am not sure if i uploaded the video correct here in SIEMENS Forum , Either you can check from Here. |
Last edited by: Inv0ker at: 08/19/2020 09:54:08Last edited by: Inv0ker at: 08/19/2020 09:55:17 |
8/19/2020 10:57 AM | |
Posts: 137 Rating:
Hello Prof.Frink, here is the testProject, i assume that the connection is working, otherwise TIA will show me error or i can't open the Panel. btw i just try to swap the Basic Panel with Comfort panel and everything fine and work perfect.
sorry, now you will find the correct project with BasicPanel AttachmentBasicPanelTest_1.zip (149 Downloads) |
