8/4/2016 10:25 AM | |
Joined: 12/6/2007 Last visit: 3/12/2025 Posts: 12 Rating:
windows 7 ultimate sp1 64 bit step7 v5.5 sp4 |
8/4/2016 10:29 AM | |
Joined: 5/12/2006 Last visit: 3/20/2025 Posts: 22572 Rating:
Hi, and which WinCC? Try the following: Open Windows Device Manager
Christoph |
9/12/2017 10:13 AM | |
Joined: 3/2/2007 Last visit: 3/20/2025 Posts: 980 Rating:
" simatic filed pg m4 cp5711 " how did you solve this issue ? thank you |
... thank you ... |
9/12/2017 10:47 AM | |
hi, have you tried the suggestions from ChristophD? If no, try it? If yes, what´s the status? regards, |
FCK WAR! |
10/23/2017 7:55 AM | |
yes, i tried. it is solved. the cp5711 was not appearing in the set pg/pc interface. in the device manager, it was with a yellow mark, and a message of uninstalled driver. then i installed the driver by selecting browse for it in the c harddisk . thank you for your help. |
... thank you ... |
10/23/2017 1:37 PM | |
Joined: 8/3/2009 Last visit: 3/20/2025 Posts: 15045 Rating:
Hello Ziemens do you need still any help or does the CP5711 work now at your computer? It was not able to read out this information out of your last post without a doupt. Bye Murof |
10/24/2017 7:23 AM | |
yes, it is working fine. thank you |
... thank you ... |
