9/16/2015 8:25 AM | |
Joined: 4/24/2006 Last visit: 2/7/2025 Posts: 8839 Rating:
Hello Atzze, Do you have WinCC flexible integrated in Step 7? Or are you using TIA Portal? Best regards, Wizard |
9/16/2015 11:03 AM | |
Posts: 8 Rating:
Attachment |
Hello, Perhaps the following link might help: how do you integrate a WinCC flexible project in STEP 7? @edit: When you program a HMI display in hardware configuration, you are planning to use Direct DP keys!!!! Only in Netpro, you will normal see your HMI panel.
9/16/2015 11:04 AM | |
Posts: 8 Rating:
Attachment |
