3/12/2018 1:06 PM | |
Joined: 5/28/2008 Last visit: 3/28/2023 Posts: 4391 Rating:
Hello, Yes it is possible. Please revise the section of "process coupling" in the following link: https://support.industry.siemens.com/cs/us/en/pv/6AV2124-0JC01-0AX0/td?dl=en |
Ayman Elotaify |
Posts: 648 Rating:
Hey raresoc, here you can find the Information which PLCs are supported and how to realize the communication:
With best regards rh1990 |
3/12/2018 1:10 PM | |
Joined: 9/27/2006 Last visit: 3/28/2023 Posts: 11997 Rating:
Hello raresoc: The following document simply states that the TP 900 supports Ethernet/IP communications. Use the Online help in your WinCC Comfort to find out details on how to implement thhe link:
https://support.industry.siemens.com/cs/ww/en/view/49313233 This FAQ can give you a bit more information as well, use the attached RS-Logix demo project to see how the driver can be setup in your application:
https://support.industry.siemens.com/cs/ww/en/view/109475773 Hope this helps, Daniel Chartier |
3/14/2018 11:32 AM | |
Joined: 4/6/2017 Last visit: 6/16/2022 Posts: 69 Rating:
Thank you all. |
