6/10/2015 10:00 PM | |
Posts: 439 Rating:
Hi, Last month I configured a comfort panel as OPC UA Server and tested it with OPC Scout V10 of the SIMATIC NET V12 SP2 installation, everything works good! You can find the procedure I did join to the post. Last week, I upgraded my SIMATIC NET to V13 and I can't connect to the OPC UA Server of my comfort panel. If I connect an other computer with NET V12 SP2, everything is ok. I realize when you connect with NET V12, a message appears to upgrade the certificate and there is no message in NET V13. So, I suppose I must import certificate somewhere in NET V13. I looked in the "Communication settings" of the "Control panel", but I'm not sure how to do this... Do you have an idea? Best regards, Hugo AttachmentOPC UA Server avec Comfort panel - EN.pdf (909 Downloads) |
