6/17/2020 10:47 AM | |
Joined: 10/7/2005 Last visit: 6/5/2023 Posts: 2966 Rating:
Unless you check your S5 program to see if it fits and will work in a CPU 100, you may be out of luck trying to get your CPU 103 program into it. Attached is a pic which highlights the key capabilities differences between the two CPU's an the manual to help in general is available HERE. Bottom line, assuming your original program does:
you may have a winner (but - as said - you need to check your S5 program first and my advise is to get another CPU 103). |
Cheers |
2 thankful Users |
6/17/2020 2:20 PM | |
Posts: 9 Rating:
Yes Sir, we will buy one with the same specs. Thanks for the technical support. |
