1/14/2011 8:46 AM | |
Posts: 141 Rating:
KeremKu has the same problem like me, so I hope its ok for me to jump into the discussion. jacek d, what do you mean by "does a lot"? My function reads and writes data from DB using OPN command. In this case, it reads appox 10 values and writes approx 10 values. It uses few miliseconds to execute the function. Setting to Process mode will surely prevent PLC to go to stop mode, but that still prevents me from debugging... |
