6/5/2006 11:39 AM | |
Posts: 14 Rating: (1) |
How communicate S7 300(master) with M-bus (meter bus) equipment (slave) ? |
6/5/2006 2:05 PM | |
Thank you very mach |
3/19/2009 12:50 PM | |
Posts: 5822 Rating: (412)
Hello, about M-Bus there is also a solution for CP 341, this CP might be used within a ET200M unit too, available. This solution is being tested with the shown units within the PDF file I add to this post. If you are interested in this software please contact the international technical Support. Best regards J_Bell AttachmentAH01_2008-07-22_M-BUS_to_SIMATIC_S7_M-Busgeräte_EN.pdf (1085 Downloads) |
