11/4/2010 2:17 PM | |
Joined: 6/7/2010 Last visit: 7/9/2024 Posts: 571 Rating: (37) |
Hello, What error is comming ?, in which the error is comming ? & could you explain briefly. Muthamizh. |
Regards, |
11/5/2010 4:50 PM | |
Posts: 8 Rating: (0) |
hello S7-legend I will presented by the specific error of attachment. the screen reflected tension (green) with large amplitude This signal is sent to the load cell PLC (analog block), then from the PLC to HMI. actual signal is not so high. So the problem is where? HMI, PLC, Program ... Dangtuan AttachmentDoc11.zip (162 Downloads) |
