8/1/2012 9:54 AM | |
Joined: 5/28/2008 Last visit: 4/26/2025 Posts: 4520 Rating:
Hello again, Please tell us what is the Serial number of your panel? Serial number define which period this panel was produced. And according to 7th post of thisthread, your panel may be affected by this problem. Check and inform us. And if your panel was produced from 06/03/2011 to 06/30/2011, then you can Contact your local Siemens representative and replace it.
Hope this helps.
Ayman Elotaify |
8/15/2012 11:54 AM | |
Joined: 4/24/2006 Last visit: 4/25/2025 Posts: 8969 Rating:
Hello Buestad, Have you tried an OS update with the option "Reset to factory settings" (You will need MAC Address) Here is a link how to proceed: how do you do an operating system update (OS update) on operator panels? Best regards, Wizard |
8/15/2012 4:06 PM | |
Hello Buestad, Have a look at this link: What transfer options are available in the various operator panels? The USB PC adapter is not possible. And the CP5711, I doubt it will work with WinCC flex. 2007. Best regards, Wizard |
