11/28/2013 8:19 AM | |
Posts: 5 Rating: (2) |
hi it seems that a fuse in burned in my SIMODRIVE E/R MODUL model (6SN1145-1BA01-0BA2 VERSION D) well during start up some smoke came out of it and LEDs off after 2 seconds and the the machine halted.9 watch the video (failure to start up) I just want to check the protection fuses (see attached picture) on it and I need the manuals for it which I could not find. also if possible how to check the fuses from out side if this is applicable |
11/30/2013 2:37 AM | |
Posts: 2964 Rating: (482)
Hello, It is a new machine? all of sudden are you facing the problem Fuses are inside the module and it will be diffcult to check https://www.automation.siemens.com/doconweb/content.asp?item=12410&cd=sinumerik_simodrive_04_2010_e&scope=all docon web link attached for the reference. better send the hardware for repairs& check the machine electrical accessiores... Pegards, Prakash |
