4/3/2023 3:03 AM | |
Joined: 10/17/2007 Last visit: 9/23/2023 Posts: 3589 Rating:
see my attachment--you need connect power supply module flat cable to supply power to the control card--I think you have 611A spindle control --if you are lucky the card still good and parameters not cleaned --check P095=??? such as =12, check my form you will know drive is 400A--6SN1123-1AA00-0KA0 give my answer a rating
AttachmentSpindle_PO_motor_code.pdf (155 Downloads) |
If you like my comment, rate it (right top) or thank it (left bottom). |
