9/8/2023 8:50 PM | |
Joined: 8/31/2023 Last visit: 10/3/2023 Posts: 14 Rating:
Attachment29L0119666H_mod_elettrico.pdf (7 Downloads) |
9/12/2023 12:05 PM | |
Our spindle has no feed back, it is just a high speed induction motor. This is it, https://www.hiteco.net/en_US/products/electrospindles-a.t.c.c8190/serie-powertech-400-10---13-kw.8205/qe-2-9-6-12-63f-nc-cb.100602 I'll perform the tests you suggest and get back to you with the results. What size motor would you consider a "middle size" one? |
9/13/2023 2:16 AM | |
Joined: 10/17/2007 Last visit: 10/3/2023 Posts: 3619 Rating:
try to find same KW of the spindle motor. spindle motor No feedback will be much more easier to set up. when use SIMO COM U select "no encoder
If you like my comment, rate it (right top) or thank it (left bottom). |
