4/26/2015 11:23 AM | |
Posts: 28 Rating:
hello I am using a simotion 425 and try to use the themperature channel in order to control temperature I am using as analog in a ET200 4 AI TC ST conected to J TC I am geting a negative value at the ambient temperature can any body help? thank you Juan
Last edited by: Min_Moderator at: 4/27/2015 4:34:39 PMNew subject after splitting |
4/28/2015 11:05 AM | |
Joined: 10/11/2006 Last visit: 4/24/2025 Posts: 6009 Rating:
Hello,
check the configuration of your I/O module.
chapter 5 https://support.industry.siemens.com/cs/ww/en/view/67989094
With best regards, |
8/16/2015 6:06 AM | |
Posts: 28 Rating:
any one can tell me what parameters should be change and what should be the change in order the channel will be cooling control only? thank you Juan |
