5/2/2021 11:23 AM | |
Joined: 1/9/2019 Last visit: 3/22/2025 Posts: 88 Rating:
Hello everybody. I have a very serious problem please help me on this. I have a machine with SIMOTION D435 PLC, In SIMOTION SCOUT the programmer uses an array of TON timers for programming, one of this timers names MYTON[1] (Attached in picture ton), programmer uses MYTON[1] in about 6 function blocks (as highlighted in picture blocks), the other thing is in all of 6 blocks the programmer uses different conditions for the timer(as you can see in picture TON USE1 to 3). do you think this kind of programming CAN MAKE MISSMATCH in working of the machine?
------------------------------------------------------------------------------------------ Attachmentpics.zip (356 Downloads) |
Last edited by: Jen_Moderator at: 05/03/2021 11:28:08New subject after splitting |
5/2/2021 1:04 PM | |
thank you for your answer, most of them are using in the highlighted line in attached picture, and I think this can be the problem.
Attachmentuntitled.zip (327 Downloads) |
