8/6/2010 7:39 AM | |
Joined: 7/28/2010 Last visit: 7/16/2023 Posts: 184 Rating:
Hi, You can use Trend View in Wincc Flexible to trend the position of the cam and display it on the HMI. You can either log the positions in a Data Block and pass all the data in one shot or have a live trend which graphs the cam's movement on the screen. Regards, Behnam www.sigmaprocess.ca |
8/8/2010 1:25 PM | |
Posts: 6 Rating:
Hi, Mr.Behnam I understand use Trend View for display the cam position, but it only display, can't operate. Are you have some example for me. Best regards. Thanks. |
8/9/2010 2:23 AM | |
Xaping, I haven't done this before. But for passingdata back to PLC from Winccflex: 1. You can save your curve in a file 2. Write a script in Winccflex to read the file and pass it to tags 3. Read those tags in PLC Regards, Behnam www.sigmaprocess.ca |
