10/18/2012 10:09 AM | |
Posts: 1547 Rating:
Hello, did you check the compatibility between WinCC and SIMATIC NET Version? Was this Software delivered with WinCC? WinCC is already installed? If yes maybe a setup routine crashes. There is a possibility to clean the PC from Siemens Software. Follow this FAQ, it's for Step 7 but work also with WinCC and NET. Uninstall all software first if possible. How do you uninstall STEP 7 completely, including all the software packages? |
