11/5/2007 11:02 AM | |
Joined: 9/27/2006 Last visit: 12/3/2024 Posts: 12299 Rating: (2691) |
Hello Wim; The following link willtake you toSiemens' PCS7 portal, specifically to the Add-ons page: https://pcs.khe.siemens.com/index.aspx?Nr=6815# Under theSimulation item, you will find information on SIMBAPro and SIMIT; you can also access manuals and relevant technical info if you use the right-hand side links section. Hope this helps, Daniel Chartier |
11/6/2007 3:42 AM | |
Joined: 4/14/2006 Last visit: 12/2/2024 Posts: 75 Rating: (2) |
Here the link for SIMIT information: www.siemens.com/simit
